04-02-2018 18:52
04-02-2018 18:52
With the new update can you reply to texts on the Fitbit ionic?
04-02-2018 19:43
04-02-2018 19:43
No, it is not possible to reply to text messages on the Ionic.
Best Answer04-03-2018 14:09
04-03-2018 14:09
@Jaeykewrote:No, it is not possible to reply to text messages on the Ionic.
Not yet. Remember that another update to enable quick replies for Android is "coming soon" to Fitbit OS (both for Ionic and Versa).
You should essentially be able to do something like, checking the notification for the message and select between a few predetermined options to quickly reply to that message.
Since you're able to change the default "messages" app for notifications, you may be able to do that with third party apps such as Facebook's messenger or Whatsapp. But we'll have to see.
05-07-2018 19:32
05-07-2018 19:32
It's May 7th....when is this feature coming out???
Best Answer05-08-2018 03:57
05-08-2018 03:57
It has arrived in the latest firmware update that is slowly rolling out.
It is currently only available for users paired to an Android phone.
05-08-2018 13:42
05-08-2018 13:42
Very slow....anybody have it?
Best Answer05-08-2018 15:21
05-08-2018 15:21
@SunsetRunner Yes, I have it. Works as advertised though limited to 5 canned replies (though you can change them per application you reply from)
Best Answer05-08-2018 17:38
05-08-2018 17:38
Best Answer05-09-2018 01:06
05-09-2018 01:06
@SunsetRunner Yeah, I am waiting too! I keep checking the app to see if it is here yet!
Helen | Western Australia
05-09-2018 02:10
05-09-2018 02:10
So, when will this feature be added to iPhone users?
Best Answer05-12-2018 15:38
05-12-2018 15:38
Mine rolled over too, but now I'm not getting ANY text message notifications coming through. I get everything for every other app but that one.
Anyone run into this same issue and have a solution?
05-12-2018 18:28
05-12-2018 18:28
I just updated my Ionic however I do not receive text messages and I can not text to a missed call. I do get emails and I receive phone calls. Any body have a suggestion as to why? My Ionic is set to receive messages on my phone and my Fitbit.
Best Answer05-12-2018 18:36
05-12-2018 18:36
Best Answer05-12-2018 18:40
05-12-2018 18:40
Best Answer05-12-2018 18:43
05-12-2018 18:43
Best Answer05-12-2018 18:48
05-12-2018 18:48
Best Answer05-12-2018 18:50
05-12-2018 18:50
Best Answer05-12-2018 18:51
05-12-2018 18:51
Best Answer05-12-2018 18:53
05-12-2018 18:53
Best Answer05-12-2018 18:55
05-12-2018 18:55
