11-19-2017
02:37
12:54
MattFitbit
11-19-2017
02:37
12:54
MattFitbit
I am locked out of my ionic. It is saying to unlock with my phone however I have tried to change my pin in the iPhone app but after the process is complete I get a message saying “change pin failed”
its extreamly frustrating
Moderator edit: edited title for clarity
06-27-2019 00:59
06-27-2019 00:59
08-26-2019 13:13 - edited 08-26-2019 13:15
I'm stuck in a weird loop on resetting my PIN. I try to reset it and I get this code:
Change PIN Failed
Sorry, there was a problem changing your Device Lock PIN. Please re-enter your existing PIN to continue.
I re-enter the last known PIN and get this error:
"An unexpected error occurred. Please try again later."
Steps I've taken (after each step I attempted to change PIN unsuccessfully):
Remove and reinstall card for Fitbit Pay
Unpair and pair Ionic/Bluetooth
Shutdown and restart Ionic
Remove and reinstall Ionic
Quit and restart Fitbit app
Remove and reinstall Fitbit App
Any other suggestions? Thanks in advance!
09-01-2019 12:52
09-01-2019 12:52
09-02-2019 12:40
09-02-2019 12:40
I finally got mine to work! The ionic would give me an error message then ask for the previous PIN (default). I entered 1234 and was able to change my PIN. Good luck!
09-02-2019 14:12
09-02-2019 14:12
Tried it immediately..but no such luck.. thanks anyway!
09-02-2019 14:12
09-02-2019 14:12
10-13-2019 23:32
10-13-2019 23:32
This totally helped with my Ionic. I looked for ever on line for this!
So If your ionic is locked and not linked via Bluetooth to any devise, these steps factory reset, so you may lose all data that was not synced!
10-21-2019 10:44 - edited 10-21-2019 11:00
This is for the people who have sifted through all the pages of responses only to find they have wasted time. You can't change the pin unless you know the old pin. There simply isn't a way on the app to reset it.
What I did was factory reset the watch by going into settings on the watch, in the about area.
Then It went through all the updates and synching which took about an hour and a half. When it tells you to open the fitbit app, just select that this is replacing the old one, and it will keep the clock and other apps that were previously downloaded. Most importantly, you can set a new pincode.
11-09-2019 20:59
11-09-2019 20:59
Hi could someone help me.
I am wanting to reset my pin on my phone as it says I have one already set up but I can't remember it.
My ionic watch isn't locked.
I have one attempt left.
It doesn't give an option to reset it.
My phone is a Google pixel.
I can't set up the wallet without resetting the pin.
11-09-2019 21:11
11-09-2019 21:11
11-11-2019 02:30
11-11-2019 02:30
Mackiespi, Thanks so much I couldn't see your message previously.
Worked perfectly
11-11-2019 05:33
11-11-2019 05:33
01-15-2020 18:08
01-15-2020 18:08
Hey, my sister tried to figure out my code on my Ionic fitbit, and now i cant unlock it! So i went to my phone and went to pin and said "failed to contact authorization". So i decided to delete my Ionic fitbit on the app and restart the whole thing over again, and now it said "connected" "please type the 4 digits on your phone that popped up on the screen", but on my fitbit it said "unlock on your phone". so now im in a huge mess. can anyone help me with this problem?
01-15-2020 18:54
01-15-2020 18:54
01-16-2020 15:42
01-16-2020 15:42
This worked for me. I get this issue with PIN being locked every few months. In the past I just did a factory reset and set everything back up which was a pain. This is the first time I fixed the issue without a factory rest. Now, if I can only figure out an easier more consistent way to transfer music...thanks!
