01-01-2018 19:48
01-01-2018 19:48
Hello, anyone else having this problem with their Ionic where the Screen Wake setting is missing? I noticed something was wrong when my watch suddenly stopped waking when I turned my wrist up to look at the time. I went into settings and the screen wake setting was gone. I also soft reset the device and still no fix. Your help would be greatly appreciated hoping not to have to hard reset.
03-21-2018 03:46 - last edited on 10-28-2019 06:51 by AlvaroFitbit
This did not work, I get the Fitbit wallet.
Moderator edit: removed personal information
03-21-2018 03:48 - last edited on 10-28-2019 06:53 by AlvaroFitbit
I stopped receiving notifications as well.
I’ve used all of the fitness functions and some of those don’t operate properly; hear rate and steps.
I’m over it as well, very disappointed.
03-21-2018 07:32
03-21-2018 07:32
John, long press the left button AND then swipe the screen probably right but could be left and the Screen Wake and Notifications screen will appear.
03-21-2018 10:50
03-21-2018 10:50
Thanks CB...I found the setting for "screen wake." Who would think to look for the "screen wake" and "music" features under the screen for the "Wallet/Pay."
03-21-2018 14:47 - last edited on 10-28-2019 06:55 by AlvaroFitbit
Done! Thanks!
03-22-2018 21:39
03-23-2018 08:06
03-23-2018 08:06
03-23-2018 19:09
03-23-2018 19:09
Wow, thanks a million!!! I kept swiping right and was getting NOTHING! Pressing and holding the left button brought the sleep wake setting up immediately!
03-26-2018 10:27 - edited 03-26-2018 10:31
Hi,
Had the same issue of swipe right not showing screen wake setting. Had to press and hold the single button on left side and the menu opened up.
You may want to try this too..
Edit : Just noticed others had shared this fix already. 🙂
Ashok
03-26-2018 14:57 - last edited on 10-28-2019 06:59 by AlvaroFitbit
Thanks. That worked!
03-27-2018 00:28
03-27-2018 00:28
Totally annoying. Since the last update, the only way I could find the screen wale setting was a tip on here to hold down the left button for two seconds. This is neither intuitive nor intelligent design - I would never of guessed how to find that setting.
03-27-2018 15:43
03-27-2018 15:43
That worked! So to get to “Screen Wake” option, you hold left button. Sweeping left to right no longer works.
04-11-2018 04:36
04-11-2018 04:36
I have face this problem again after the lastest version updated. How can I set my fitbit to be auto screen wake ?
04-11-2018 05:07
04-11-2018 05:07
Hold left button. I’m will lead you to wake screen and notifications optoions.
04-11-2018 05:28
04-11-2018 05:28
Thank you very much.
04-11-2018 06:12
04-11-2018 06:12
Sorry about misspellings and punctuation, typed in a hurry. I just figured how to find screens a week ago, glad to help.
04-19-2018 09:16
04-19-2018 09:16
Updated Solution:
Since the last firmware update, This solution no longer works. I had the same problem, and discovered that swiping will not take you to the setting, nor will going into “settings“. You’ve got to go to the Clock screen, hit the button on the left, and then when the Screen turns off, press and hold the button. The options to change screen wale, and to turn notifications on/off ( and, strangely, nothing else) will pop up.
04-19-2018 13:58 - last edited on 10-28-2019 07:14 by AlvaroFitbit
Yes - that's it!
04-25-2018 00:46
04-25-2018 00:46
I found mine by holding down the left button for a few seconds.
04-25-2018 00:47
04-25-2018 00:47
