01-01-2018 19:48
01-01-2018 19:48
Hello, anyone else having this problem with their Ionic where the Screen Wake setting is missing? I noticed something was wrong when my watch suddenly stopped waking when I turned my wrist up to look at the time. I went into settings and the screen wake setting was gone. I also soft reset the device and still no fix. Your help would be greatly appreciated hoping not to have to hard reset.
04-25-2018 06:24
04-29-2018 09:11
04-29-2018 09:11
This is the solution for the watch 2 OS (2018)
05-06-2018 19:34
05-06-2018 19:34
Thank you! This worked!
05-09-2018 21:31 - edited 05-09-2018 21:34
Hi!! So I've seen this solution everywhere, problem is I CANNOT swipe right. Nothing happens. I had a different screen on from default and thought maybe that affected it somehow but when I switched back to a fitbit clock face I still can't swipe right. There is no Raise to Wake setting that I can find anywhere. Please help, thank you!!!
***ugh, disregard. have to hold down the left button for 2 secs, no more swipe right.
05-15-2018 14:12
05-15-2018 14:12
Swiping right on my Iconic does nor bring up the Screen Wake option
05-15-2018 14:47
05-15-2018 14:47
@SunsetRunner wrote:Swiping right on my Iconic does nor bring up the Screen Wake option
That's correct! As the post just above yours says, a long press of the left button now brings up the Screen Wake setting.
05-19-2018 00:11
05-19-2018 00:11
My mental telepathy is not up to it these days- who would have guessed that one!
05-19-2018 07:10
05-19-2018 07:10
User Manual See page 18.
05-19-2018
08:46
07:15
AlvaroFitbit
05-19-2018
08:46
07:15
AlvaroFitbit
Hello,
Ah, I still had the previous manual, didn't know that it had been updated.
Thank you.
Dennis
Moderator edit: removed personal information
05-19-2018 15:15
05-19-2018 15:15
Press and hold the left button. The screen wake options come up.
05-20-2018 19:52
05-20-2018 19:52
Thanks Imeson79,
Your procedure worked for me, with no help from Fitbit support.
05-21-2018 16:34
05-21-2018 16:34
Same problem here. No screen wake on doing right from watch face. And no screen wake from settings. What gives??
05-21-2018 16:41 - edited 05-21-2018 16:45
How to get that setting is thoroughly discussed in the posts just above yours. See post 46 for my last answer.
05-21-2018 19:37
05-21-2018 19:37
Almost.
I have to hold down the left button, then my Fitbit pay card shows. From that window I have to swipe left, then the wake option appears.
Thanks for the help.
05-24-2018 16:42
05-24-2018 16:42
Same here. Did you find a solution?
05-24-2018 16:43
05-24-2018 17:00
05-24-2018 17:00
05-24-2018 17:16 - edited 05-24-2018 17:18
Hold down the left button and the Screen Wake setting will appear.
05-26-2018 14:19
05-26-2018 14:19
That’s brilliant thank you. I’m now sorted.
06-11-2018 06:48
06-11-2018 06:48
OMG thank you so much. I have been going crazy trying to find this menu!
