02-22-2018
03:54
04:28
02-22-2018
03:54
04:28
Options: Always Connected + Keep-Alive Widget = no sync
Anyone else had this problem? Worked perfect efter i unselected these two options again.
02-22-2018 04:28 - edited 05-19-2025 10:47
Welcome to the Fitbit Community @Peter76! Below are the causes of syncing issues:
Depending your Android device, these tips might make syncing easier:
If those steps don't work, try these steps:
Give this a go and let me know how it goes!
02-22-2018 06:05
02-22-2018 06:05
Hi and thanks for your reply.
I forgot to mention i did all of those steps and nothing worked until i Unchecked these options: Always Connected + Keep-Alive Widget = no sync.
Efter that everything worked Good, but, apperently i cannot idé those options för done respons.
I have a samsung s8.
02-22-2018 06:08
02-22-2018 06:08
Hi again. I also never needed to do this:
5. Uninstall and reinstall the Fitbit app.
02-22-2018 06:18
02-22-2018 06:18
And, telephone spelling, should be:
After that everything worked good, but, apperently i cannot use those options for some reasons.
