I recently purchased a new Fitbit Ionic about a month or so ago, upgrading from my Charge HR. In the last couple of weeks, I noticed that the Ionic would add hundreds and hundreds of steps to my step count while I was sitting on my butt at home or at work. I couldn't figure it out for a while, and I would end my work day with around two to three thousand unstepped steps, which is not an insignificant number. This problem continued at home, though to a lesser extent.
I would try and limit all of my movements, thinking that maybe I could be typing "too hard" or increasing my step count by wrist movements. But this wasn't the case. Sure, typing would add a few steps to the count, but a very small amount.
Finally, I discovered that simply having a fan blowing on me was the cause of the problem. I went without using my fan and the problem stopped completely. As soon as I turned it back on, the steps started going up again. I tried to reposition the fan, have it farther away and blowing on my side opposite from where I wear my watch, but it didn't make a difference.
I'm a fairly warm natured guy. I sometimes have a fan blowing on me even in winter. Do I really have to make a choice between wearing my Ionic and using a fan? And frankly, I have no idea how the fan is causing it to register steps in the first place. If there is a solution to this, I would love to be able to have my fan and wear my Ionic without getting fake steps.
Let's say you have the fan placed on the table you have your arm. The vibration caused by the fan could be interpreted as steps by the ionic, based on the information of this topic.
Other than that, I've never heard of just wind causing the ionic to pic steps.
