01-02-2022
00:42
06:05
01-02-2022
00:42
06:05
Not having a great start with this device. My new Fitbit Luxe is over calculating step by 1,000s! Apparently I must run around in my sleep too as I wake up to several hundred steps in the morning. I've read somewhere to wear it on my non-dominant wrist but it seems to make little difference. The 'stride' setting is on automatic and I think that distance is about right for me. Any suggestions?
01-03-2022 06:11
01-03-2022 06:11
Hi there, @JuliaDM1. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out. I understand where your concern is coming from.
The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer08-30-2022 22:38
08-30-2022 22:38
Hi Julia. I have exactly the same problem! I hate the Luxe for accurate step counting. I must have been sleep walking! I even tried attaching to my ankle but that didn’t work. All suggestions in this forum have added no value. My step counting is still out by the 1000s!! However, Pacer on my iPhone counts perfectly. Wish I hadn’t purchased! Good luck to you! Good news - I am awarded lots of badges for accruing so many steps! Laughable if it wasn’t so sad.
08-31-2022 05:15
08-31-2022 05:15
Hi there, @Janny51. Thanks for stopping by in the Community Forums and already trying to troubleshoot the issue with your Luxe before reaching out. We‘re taking your comments and sentiments in regards to our products into consideration.
If you feel that your step count and distance are inaccurate, confirm the following are correct in the Fitbit app:
Since we use height to estimate your walking and running stride lengths, you may want to measure and manually adjust these values if your legs are longer or shorter than average. For more information, see: How do I measure and adjust stride length for my Fitbit device?
Hope this helps.
Best Answer09-02-2022 18:09
09-02-2022 18:09
Best Answer09-03-2022 09:14
09-03-2022 09:14
@Kibara Is your wrist setting on ‘Dominant’? I still wear it on my non-dominant wrist, but changing that setting in the app made my step count more accurate.
Best Answer09-03-2022 18:22
09-03-2022 18:22
Best Answer09-03-2022 21:46
09-03-2022 21:46
@Kibara You said you have it set to “non-dominant”. If you feel like you are getting too many steps, then you want “dominant”. That will make it less sensitive to small movements.
Best Answer09-04-2022 09:25 - edited 09-04-2022 09:25
Oh I see. I’m wearing it on my non-dominant wrist but should change the setting to dominant. I’ll try that! Thanks for the suggestion!
