03-14-2024
14:54
04:53
03-14-2024
14:54
04:53
My fitbit will not turn on
Best Answer03-14-2024 21:19
03-14-2024 21:19
Hi @jazbiz - try charging the watch from a PC, check it doesn't get hot and if so stop immediately as it confirms a fault.
If the charging is not working see instructions to clean and verify connections in How to check charge cable - Sense 2/Versa 4 won't charge, won't start or blank screen
Once it's been charged try holding the watch button for a full10 seconds till it vibrates and wait for the logo to appear and for it to start if it isn't faulty.
You can always chat via the Fitbit App, Help & support section, Contact Customer support.
Best Answer03-15-2024 04:57
03-15-2024 04:57
Hi there, @jazbiz. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Fitbit device is not turning on. We're here to help!
As @Guy_ has recommended, please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If that doesn't work, follow Guy_'s advice and chat with us online or give us a call. Click here to get connected.
I've moved your post to the Luxe board for organization purposes.
