04-10-2024 12:14
04-10-2024 12:14
On my Versa 2 the app has recently started shown the same data for consecutive days. Shows 7034 steps today, 7034 steps yesterday & 7035 steps Monday. The previous days are correct. If I close & restart app it sorts out, but after an hour or so problem back again.
On line chat support say restart app (which I’d told home I already had), resrtatt phone, turn off Bluetooth & repair, delete app & reinstall then setup again. Done all that but doesn’t fix.
Anyone else having the problem? Any suggestions?
04-15-2024 15:29
04-15-2024 15:29
@sasw1963 , Thank you for your reply and confirmation.
Please charge the Luxe for at least for 30 minutes. Then try the following
04-16-2024 19:40
04-16-2024 19:40
It’s showing same number steps for each day. I’ve logged off the app, waited and logged back on. I’ve restarted phone. Any guidance? Tx!
04-16-2024 20:22
04-16-2024 20:22
First look at fitbit.com dashboard which usually more accurately reflects the database, hopefully to find out if it is that way in the database, or a display problem in the phone app. Then write down the number displayed in the app so you remember it, and compare that to the number of steps you get tomorrow and if they are the same, see if it changes to tomorrow's number.
Also look at the weekly and monthly step display numbers to see if they are all the same or are accurate, all just to gather more information.
04-17-2024 04:18
04-17-2024 04:18
04-17-2024 08:21
04-17-2024 08:21
Same for me and my wife. The app is displaying todays same Step Count when I am in the app and on the main today page and then flip to yesterday or even further days back. I know it is only the display because if I go to the Steps section and click it and then switch from Daily to Weekly view it shows all of the correct and different daily steps.
This has been happening for at least a couple weeks, perhaps even 3 weeks now, just not sure when it started. I have the Charge 5 version 20001.194.91
04-17-2024 08:35 - edited 04-17-2024 08:37
Never mind.
04-17-2024 21:40
04-17-2024 21:40
04-18-2024 06:34
04-18-2024 06:34
That certainly doesn't mean this is the way things should be, but at least the data isn't bad in the database. If they ever fix the display problem, then the data should still be good.
04-18-2024 15:31
04-18-2024 15:31
When I sync my (original first) versa the number a steps and floors, are all the same everyday. I know this is not correct. The software is up to date. I have an iPhone how do I fix this please anyone. Many thanks in advance.
04-20-2024 07:06
04-20-2024 07:06
Step count is same for last few days on Home Screen, despite sync? Any suggestions?
04-20-2024 20:29
04-20-2024 20:29
Hi @jayney71 - it would seem the Fitbit App has stopped working.
You can verify this by using the web dashboard which should show your information.
Logout of the Fitbit App and swipe off the active window and in Android clear the storage cache and force stop it before restarting the watch and phone.
Login again and sync.
04-21-2024 04:09
04-21-2024 04:09
04-24-2024 12:22
04-24-2024 12:22
Hi,
I’ve got something really weird going on….when I’m scrolling through the past days the step counter shows the exact number of steps as the last day (today)
Somebody got any idea what’s going on and how I solve this?
any help is welcome!
tanx!
Dico Bruin
04-24-2024 21:03
04-24-2024 21:03
My sense is showing the same number of steps for every day of the week. It shows today’s count for everyday. Please advise
04-27-2024 23:11
04-27-2024 23:11
My Fitbit verse 2 is registering the same amount of steps for the last week also the calories burned. And registering way too many floors a day.
04-27-2024 23:23
04-27-2024 23:23
Hi @Ilovecayce1 - if this is displaying on the watch try restarting the watch by holding the watch button for 10 seconds till it blanks or vibrates and wait for the logo to appear and for it to start.
Also it can be a clock face fault, to check, swipe up the watch face to get to the Today app and see if there are normal results there.
04-28-2024 12:30
04-28-2024 12:30
I am having the same exact issue
04-29-2024 11:31
04-29-2024 11:31
Today I have done 11,855 steps a lot more than in previous days, I have scrolled through my days within my app though and it appears to have wiped all the actual steps for that day and put in exactly the same number of steps as todays!
I have a Fitbit Luxe which isn’t very old.
I've unlinked all devices from my app. I even unlinked my Luxe and reconnected it.
I’ve tried putting it on charge and tapping the button 3 x until the Fitbit symbol appears and nothing seems to correct the incorrect information. Can anyone help?
04-29-2024 12:53
04-29-2024 12:53
@Lsierra , A warm welcome to the Community! Thank you for your message.
Do you have any other Fitbit or Pixel devices paired to your Fitbit account?
If not you might have MobileTrack on.
This feature uses the phone's sensors to count steps. This is for when you have left your Fitbit at home (e.g. while charging). Please make sure MobileTrack is not activated.
It may happen that the steps recorded with the cell phone overwrite those of the Sense .
In the Fitbit app, tap the devices icon (top left corner).
There you will see the devices linked to your account.
If you see the Mobile Device Active option, tap it and remove it from the account.
If you are still having difficulties with the sync, please have a look at this: Why won't my Fitbit device sync?
04-29-2024 17:11
04-29-2024 17:11
I am having the exact same issue!,!
I also deleted the app and unlinked my Fitbit, also a Luxe! I show exact same number of steps every day at 16,017. Going back a week. I did not have this issue yesterday.
