07-19-2018 06:03
07-19-2018 06:03
How do I set my bmr on my zip Fitbit?
Best Answer07-19-2018 08:55
07-19-2018 08:55
Use an online calculator such as this one, and play with your height and/or your age until you get what you believe is the correct BMR value for you. Then enter that height and/or age in your Fitbit profile.
Dominique | Finland
Best Answer07-19-2018 07:23
07-19-2018 07:23
There's no need. Your BMR calories are calculated automatically based on your profile settings for age, height, weight etc.
Best Answer07-19-2018 07:45
07-19-2018 07:45
If I wanted to edit it how do I do that?
Best Answer07-19-2018 07:47
07-19-2018 07:47
You can't directly change it. The only thing you can do is to tweak your profile settings until you get the numbers you think your BMR should be.
07-19-2018 08:52
07-19-2018 08:52
How do you do that?
07-19-2018 08:55
Dominique | Finland
