07-20-2018 14:46
07-20-2018 14:46
How does the Fitbit keep track of body fat loss?
Best Answer07-20-2018 15:21
07-20-2018 15:21
I use an Aria scale to auto input the data, if you don't have one and are manually logging what your scale reports, do it by touching weight on your mobile, hit the plus sign in the upper right corner, enter the value(s). You can track your progress by again touching the weight tile on the fitbit screen, and swiping right twice.
Keep moving @B3
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
07-20-2018 15:21
Keep moving @B3
WmChapman | TX
