02-15-2014 20:27
02-15-2014 20:27
Hello I am new to fitbit and was wondering if parts of my dashboard and trainer are going to dissapear after this first week. So far I really like it and feel like its helping me. What is the difference between the regular and premium service and what has helped you reach your goals more effectively?
Best Answer03-26-2019 06:47
03-26-2019 06:47
Does the premium track DAILY food or will myfitnesspal transfer to my Fit bit app.?
Best Answer03-26-2019 07:07
03-26-2019 07:07
Fitbit premium is guided workouts. Food log comes with Fitbit.
03-26-2019 14:40
03-26-2019 14:40
@brenna22 wrote:Does the premium track DAILY food or will myfitnesspal transfer to my Fit bit app.?
Fitbit premium is an old service and is no longer available.
Yes, you can link your MyFitnessPal account to your Fitbit account. You set it up on the MFP site.
Scott | Baltimore MD
Best Answer09-14-2019 14:13
09-14-2019 14:13
There are other free apps that work with fitbit that do that as well.
Best Answer09-14-2019 14:16
09-14-2019 14:16
If you touch the graph on the sleep pattern it does show you the amount of time in each section. ( on the free program not the premium)
Best Answer09-14-2019 14:19
09-14-2019 14:19
What is a "startup founder" for fitbit?
Best Answer09-14-2019 14:22
09-14-2019 14:22
What is a "startup founder" ?
Best Answer09-14-2019 14:27
09-14-2019 14:27
You can track your calories in the original fitbit (not premium). I used to use WW, but when I got my fitbit I quit paying for WW because my Fitbit did the same thing, but with calorie counting rather than points.
