10-18-2017 07:39
10-18-2017 07:39
So I just bought the RENPHO Scale that syncs with Fitbit. I was going to buy the Fitbit scale but from the reviews and cost I went with RENPHO Scale. Anyone have any good things to say about it?
10-18-2017 11:39
10-18-2017 11:39
First time I hear from them (they appear to be a very young company, two years old). Hope your new scale willl serve you well and you were able to link its app to the Fitbit app. If you have done it already, do you get both weight and body fat data in Fitbit?
Dominique | Finland
10-18-2017 12:14
10-18-2017 12:14
Dunno just ordered it from Amazon I will get it tomorrow. Honestly I would have liked the fitbit scale but it had really bad reviews.
I downloaded there app and linked it already to fitbit. once I get the scale I will sync with both apps. We will see
10-24-2017 12:44
10-24-2017 12:44
@bryandrev wrote:Dunno just ordered it from Amazon I will get it tomorrow. Honestly I would have liked the fitbit scale but it had really bad reviews.
How is it working out for you.
11-15-2017 05:25
11-15-2017 05:25
I just got the Renpho scale - my husbands phone connected without issues. Mine on the other hand refuses to sync (my phone is much newer than the husbands).. but, the good news is that when I enter the weight into the RENPHO app, it syncs to fitbit right away. So, if I can get my phone to work right with the scale (through bluetooth), this will be pretty awesome.
11-15-2017 06:47
11-15-2017 06:47
I noticed mine is goofy too. It appears that I habe to do it twice. Make sure you have connection to fitbit through the app. take measurement. Go back look at connection to fitbit, mine is normally turned off once I measure so I turn it on again and re measure. Seems like a bug
12-30-2017 15:01
12-30-2017 15:01
Does anyone by chance know what the colors of the measurements mean on the app? I know they’re related to the sliding scale, but for instance my weight and bone mass are yellow while everything else is green, is that indicating that having high bone mass is bad? If anyone has any ideas I would love some help, thanks!
12-30-2017 18:15
12-30-2017 18:15
12-31-2017 00:01
12-31-2017 00:01
@MReilly wrote:my weight and bone mass are yellow while everything else is green, is that indicating that having high bone mass is bad? If anyone has any ideas I would love some help, thanks!
I’m not using this particular scale, but I’d guess this means your bone mass is slightly lower than would be expected for someone your age and your size. Yellow weight, OTOH, would indicate you’re either underweight or overweight (as per BMI).
However, I wouldn’t pay too much attention to bone mass estimated by a scale. Bone density is likely not an issue given your age, unless you’re eating a diet that results in severe deficiencies.
Dominique | Finland
12-31-2017 00:34
12-31-2017 00:34
It does, but it’s unspecific. It just says my bone density is high, my weight is high, which doesn’t make sense from many other physical standpoints which is why I was confused
12-31-2017 00:36
12-31-2017 00:36
Thanks so much for your feedback though, much appreciated!
01-04-2018 03:22
01-04-2018 03:22
I'm looking for a decent scale that measure my BMI too.
Would you say this scale is worth purchasing?
01-04-2018 03:52
01-04-2018 03:52
@Je55 wrote:I'm looking for a decent scale that measure my BMI too.
You don’t really need a scale to measure BMI: it’s just a ratio between your weight and you height, so it doesn’t change much (on a day to day basis) and it’s displayed in your Fitbit account if you update your weight there.
Maybe you meant body fat % instead?
Dominique | Finland
01-04-2018 04:15 - edited 01-04-2018 04:38
I think I may have to explore the functions on my fitbit.
I wanted scales to measure my body fat %
01-04-2018 04:34 - edited 01-04-2018 04:35
Tanita has full body composition scales that measure BMI but the models that can do this function are quite pricey.
01-04-2018 04:47
01-04-2018 04:47
@Je55 wrote:I wanted scales to measure my body fat %
Strictly speaking, scales send a (weak) current into you body through your feet (and possibly your hands too, for some scales), measure the impedance of that current and estimate your body fat % based on that. The stress is on estimate here. There are known limitations to that method. It seems to work well for some people, and less so for others.
Dominique | Finland
01-04-2018 04:58
01-04-2018 04:58
@Je55 wrote:I think I may have to explore the functions on my fitbit.
BMI is displayed graphically (chart for the last 30 days) in the third screen found under the Weight section of your mobile app:
If your scale can sync to your Fitbit account, BMI will be updated each time you step on the scale, even if the scale itself doesn’t display BMI. This is the case with the Fitbit Aria scale, for instance.
Again, BMI and BF% are two different things (although they tend to correlate with each others).
Dominique | Finland
01-04-2018 09:14
01-04-2018 09:14
Ya! So far I really like it
01-06-2018 18:18
01-06-2018 18:18
I just pretty got this scale for myself as a Christmas gift...I know cheap gift right. Anyway I finally used it for the first time and it synced easy to my iPhone but not so easy to my android phone. I have 2 phones since one is for business. So far I like the scale. Will see how I feel about it 6 months from now
01-08-2018 12:05
01-08-2018 12:05
Point noted, very useful to know.
I've tried the online body fat calculator- entering your waste, hip, neck measurements, height, weight, age and gender . Don't know if this better than the scale, just looking for something to see meaure progress.. guess there's aways a mirror and tape measure.
