05-10-2018
11:43
15:51
AlessFitbit
05-10-2018
11:43
15:51
AlessFitbit
Hello! As a Dad, I was able to activate the Female Health Tile on my Versa and play around with it along with my daughter. Her Fitbit app is now setup. However, I have since removed the tile from my Fitbit app, but on my Versa, I have a Female Health Section at the bottom...
How can I get rid of this?
Thank you!
Moderator edit: title for clarity
06-09-2018
14:26
06:59
06-09-2018
14:26
06:59
Hi, @Jdrich811, if you could share with other users what worked that would be great! This is mainly a peer to peer help forum where users help each other.
Please explain in as much detail as you can.
08-26-2018 10:23
08-26-2018 10:23
I've figured out how to remove it from my iphone; just like a regular app. touch it until it shows the x's and then click on the x to remove the female tracker.
08-29-2018 10:22 - edited 08-04-2025 06:58
It's nice to see you around the forums @SunsetRunner! Thanks for sharing the steps that has worked for you in order to remove the Female Health Tile.
As you mentioned, to hide the female health tile:
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
09-09-2018
23:51
12:35
SilviaFitbit
09-09-2018
23:51
12:35
SilviaFitbit
I have a problem with Fitbit Versa. Actually one of my mischievous friends had activated Female Health facility in my Fitbit Versa watch. but the actual problem is that I am male and in restricted societies like India this facilities in male watches are taken as sin. So please guide me how to remove this facilities or deactivate from my watch as well as in my mobile application too. Because it constantly display this facility which may put me in trouble if the watch comes in too hands of my mother or my elder sister.
Please do the needful and reply soon.
Moderator edit: format
09-10-2018
00:38
06:58
09-10-2018
00:38
06:58
Sometimes friends aren't really thinking when they do things like that. Let's see if we can't remove it
To hide the female health tile:
Your post is being moved to a thread where other men have wanted to know to remove it as well.
Read the posts from Moderator @AlessFitbit as she guides others in removing it.
Wishing you the best.
09-10-2018 01:26
09-10-2018 01:26
09-10-2018 05:02 - edited 08-04-2025 06:58
Hey there @PARTH90SHAHVERS, thanks for jumping in here! Sorry to hear what happened. My friend @Odyssey13 and I will be more than glad to assist you.
Can you please let me know if you followed the steps provided by @Odyssey13? As mentioned in the posts she redirected you, if you no longer want Female Health Tracking on your Versa, please consider deleting all the info input for female health tracking on your Fitbit app. Once you completely remove the data inserted and then sync again it will remove the tile from your watch.
Please note that you can't remove your female health tracking data only from the device, you must remove your data from the Fitbit app to delete the information from your device. Hiding the female health tracking tile from your app dashboard does not delete your female health tracking data from your mobile app or your device.
Hope this helps, let us know if these steps work!
09-29-2018 11:17
09-29-2018 11:17
I do not have an X on the Female tracker on my Charge 2. I, and most of my friends with trackers are way past carrying about female health as you define it having been past menopause for many years. I would like to remove it.
10-01-2018 07:06 - edited 08-04-2025 06:57
Thanks for stopping by @sierras49! To remove the Female health tracking tile inside the Fitbit app, please scroll to the bottom and select "Edit." You will then see each tile toggle and you can select the "X" on the tile to remove it from the app. After that, scroll back to the bottom and click "Done."
Always make sure that you'll are using the latest Fitbit app version. Android should be on 2.79 and iOS on 2.78 as of today. Believe or not, running old versions might cause inconveniences.
If there's any questions present, let me know.
10-11-2018 06:35
10-11-2018 06:35
I wanted to show my girlfriend the new feature of female health tracking. So i set my sex to female showed her and changed back to male after. Not only the app but even the Fitbit Versa still shows the female health tracking. Any way to delete it or reset it?
10-12-2018 04:52 - edited 08-04-2025 06:57
It's nice to have a new member around, welcome @Timl163! By default, female health tracking is hidden for users who have identified themselves as male in their Fitbit profile.
If the tile is showing up on your watch and Fitbit app, it seems that maybe a period was logged accidentally. If you no longer want Female Health Tracking on your Versa, please consider deleting all the info input for female health tracking on your Fitbit app. Once you completely remove the data inserted and then sync again it will remove the tile from your watch.
Hope this helps, let me know if these steps work!
10-18-2018 03:34
10-18-2018 03:34
I tried to remove everything. But it still did not fix anything. On my account im set as male, but my girlfriend told me it looks like im still set as female when she looks at my profile. Maybe thats the reason why it wont work.
10-19-2018
05:45
06:57
10-19-2018
05:45
06:57
Thanks for getting back @Timl163.
You have a really good point there! If your account was set as female by accident it will automatically give the option to see Female Health tile, and even if you change it to male this option might remain there. This is not the expected behavior of the Fitbit App, but it is possible.
If that's the case, as @MarreFitbit mentioned you might have to hide the tile from the Dashboard to avoid having that information visible. But I understand that this might be frustrating since it is not what you were expecting to have in your Dashboard.
Rest assure that I'll pass this information along to our team. Thanks for your understanding. Let me know if you have questions about it.
See you around.
