03-01-2022 12:13 - edited 03-16-2024 07:25
Hi everyone.
Thanks for letting us know about this issue about the periods not being saved. We’re currently working to resolve it and hope to have a fix soon. Be sure to keep your Fitbit app up-to-date to ensure you receive the quickest resolution.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Please let us know if there's anything we can do to assist you in the meantime.
03-30-2022 20:39
03-30-2022 20:39
Is there an update on this? ......it's been at least 39 days now.
03-31-2022 10:24
03-31-2022 10:24
03-31-2022 11:02
03-31-2022 11:02
I tried that, bit it still won't save so I can't track manually. Thanks though.
03-31-2022 15:10
03-31-2022 15:10
Someone else mentioned it's been since Jan. That's when mine did this, but even before then it stopped saving any of the "Log Details" It saves absolutely nothing on there now.
04-05-2022 23:48
04-05-2022 23:48
Mines literally overwriting my logged data with incorrect predictions to the point that it is unusable. Logged actual, regular period last week. App decided I'm having another this week and will not accept corrections. Have had to start using someone elses app.
04-06-2022 03:44
04-06-2022 03:44
Same! So ridiculous.
04-06-2022 08:05
04-06-2022 08:05
What other app are you using? I'm looking for one. I want a free one that just lets me record them, helps estimate the next, and lets me save some details. Just basics. And that doesn't share my info, apparently a lot of them share the info they gather.
04-06-2022 08:08
04-07-2022 16:10
04-07-2022 16:10
You are the best for recommending!!!! I can do the predicting on my own.....sort of...hahaha.....I need to store the dates rather than rack my brain. So Thank You!!!!
04-07-2022 16:13
04-07-2022 16:13
Any update????!!??!! 😞 #sodisapointed!!!!!
04-07-2022 23:40
04-07-2022 23:40
When is it going to get fixed?
04-08-2022 02:47
04-08-2022 02:47
Hello,
How are you doing this morning and how was your night? I hope you are doing good and having pleasant time there now.
04-08-2022 02:50
04-08-2022 02:50
Hello,
I had this same problem but with the help of my friends I were able to solved it. How about you were you able to solve yours too?
04-08-2022 19:24
04-08-2022 19:24
My watch keeps resetting to Day 1 menstrual cycle after every 6 days. It is very annoying! I can't edit in the app either. Can you please provide an option to remove menstrual tracking from the Luxe watch since it is next to useless!
04-09-2022 08:02
04-09-2022 08:02
My only fix for this is uninstalling, the app and reinstalling the app it then accepts my edit. Its super annoying but it's the only work around I've found since the issue is yet to be fixed.
04-09-2022 12:59
04-09-2022 12:59
Worry not, because they are working on it.
04-09-2022 20:52
04-09-2022 20:52
Thanks! It worked!
04-11-2022 13:18
04-11-2022 13:18
When will this be fixed??? Not logging period correctly and not saving the details logged throughout the month. It's a major feature that's now been malfunctioning for months. Why isn't there a solution yet? I'm seriously considering another brand.
04-12-2022 13:34
04-12-2022 13:34
Good to hear that
04-13-2022 09:59
04-13-2022 09:59
How is the solution progressing?
It's a very annoying issue...
