09-06-2018
20:25
08:13
SantiR
09-06-2018
20:25
08:13
SantiR
Hello all, my one is all of the sudden having issues. It is fully charged, and when I go through the reset process I can get it to respond while it is in the charger. When I pull it from the charger I cant get it to respond, light up, sync, etc... are there other alternatives to reset this thing?
Moderator Edit: Updated Subject for Clarity
If you haven't already, I highly recommend that you go for the battery replacement. It brought mine back to life and I am consistently getting 2 1/2 weeks between charges. Good luck!
Hello @Ennabird,
I had posted a walkthrough for replacing the battery. You can find it here.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
