Hi,
my fitbit one isn't syncing anymore since last friday april 23. Everything else seems to work fine. I can charge it no problem, it is showing steps and all that.
I have a pc with fitbit connect, and it doesn't sync, but neither does it sync to my iPad and iPhone, which used to work fine (until apparently last friday) (I of course know about the need of BT etc... being enabled).
I have been on a holiday from sunday until now (wednesday evening), and I have walked a lot (and beat my previous step records), so if I have to restart the fitbit one (as read in another topic), does that delete the data that hasn't been synced so far?
thanks in advance,
Winny
Best AnswerI too am having a problem Syncing. I haven't been able to Sync since 8:47 pm on 4/26 - Tuesday night.
If the person that called Cust Service and posted their phone # got results, it would be good if they mentioned the results of the call....
I use my PC to Sync.
Best AnswerI see.... you had 2 posts and I didn't initially connect them. I will be calling today too! Thanks.
Best AnswerIt took me 1/2 hour and 2 different techs to finally get my fitbit to sync. I had to uninstall app from my Android phone then reinstall it. (now you loose you your previously saved tracking data, including foods... aggravating)Then connect fitbit to dongle on my home computer and made sure I had the app from the google play store installed ( I did). And they had me force a sync... I do have "All Day Sync" (enabled) It got very confusing, Sorry couldn't write all instuctions down... I suggest you call this number 8776234997. and get a "ticket" created. Not computer savvy and this process drove me crazy... One funny thing... at first I didn't have Internet connection on my home computer...Ummm I have Verizon, don't know if the strike has any affect on what happened to my FitBit as verizon is on Strike...
I will give this another 24 hrs to see if it still works...So far I can't search for common foods and just now got Can't connect to Fitbit... Pullling my hair out...
Best AnswerNow i am getting messages Can't Connect to Fitbit and or Connection failed... I am using an Android phone.
Best AnswerMy fitbit one also will not sync with anything since Monday 4/25/16. I've done all the trouble shooting and nothing. Has anyone called customer support?
Thank you,
Carla Jane
@wintir wrote:Hi,
thanks in advance,
Winny
