Had the same problem.
I just restarted my Fitbit One and the sync worked instantly: https://help.fitbit.com/articles/de/Help_article/1186
It worked for me, but just one time. To sync again, I have to restart every time .
Best AnswerMy One also stopped syncing. Not with iPad, not with iPhone, not with MacBook. Tried restarting my FitBit, still not working. Tried Bluetooth off and back on. No joy. MyFitnessPal data is showing. This is really frustrating. It feels like we are being herded into a newer, more expensive tracking device. If I have to replace...it will be other than Fitbit products.
Best AnswerI was so disappointed when they discontinued the One. I do not want to wear a wrist device. I'll check out the inspire when I can no longer use the One but may have to switch companies.
Per RachRach:
"I figured it out - On my phone, on the Fitbit App - I clicked "add new device" and I added the One that was already on there; it sent a number to my One, I typed it in, and it synched it to my phone. Voila. I hope this helps."
This worked for me.
It worked for me, too, but only for one time. Next time I synced, I needed to do it again.
Best AnswerSame problem started this afternoon can get it to sync with my computer just not my phone ?
Best AnswerSame issue. Won’t sync. Called support, over ten minutes wait time to speak to someone. Hung up. Hope they push a new update.
Best AnswerGreat job figuring it out! Thanks-it worked for me!
