01-21-2016 12:54
01-21-2016 12:54
Best Answer01-21-2016 13:22
01-21-2016 13:22
Congrats on your fitbit one!
The calorie burn is what you burn naturally, not based on activity/movement.
It is calculated based on your weight and height.
Hope this helps!
01-21-2016 20:38
01-21-2016 20:38
It's calculating the calories burned since midnight regardless of when you set it up. As @kawaiiko said, the calculation is based on your age, weight and height. It will re-set at midnight.
01-22-2016 04:11
01-22-2016 04:11
Hi there @helenwifey. Just to add a little to @John917's and @kawaiiko's excellent posts, here's a link to the help document pertinent to your question:
Cheers!
TW
____________________________________________________________________________
(If this tip solved the problem for you, please mark this post solved, as this will be helpful to other users experiencing similar issues.)
