Best AnswerHi, @Businesspig , I have noticed that some data syncs through and is populated across Fitbit's servers more quickly than other data. It can sometimes take a little while for the battery status to be updated. It probably will be the next time you sync. In the meanwhile there is no need to worry. Your Fitbit itself has the most update battey information, and if it is showing full charge, then it is fully charged.
Welcome to the
community!
