@bo55 Welcome to our Community! You can log food by going to the log area on your Dashboard you can also follow these instructions.
I'll be around!
Hi @bo55. Somewhere on your main dashboard page on your Samsung phone, you should see a clickable icon or hyperlink that allows you to configure your dashboard. My assumption here is that you do not have the Food tile set up on your dashboard. On my iPod for example, I have to click on the word Edit in the upper left corner of my dashboard to add tiles. You should have similar functionality on yours.
TW
____________________________________________________________________________
(If this tip solved the problem for you, please mark this post solved, as this will be helpful to other users experiencing similar issues.)
