07-13-2016 13:52
07-13-2016 13:52
Hi - I recently disconnected my original Fitbit One because it has been missing since January and tried to connect an old Ultra - but got download corrupt messages so I connected Fitbit support who kindly sent me a replacement One.... received today and was really looking forward to getting back to tracking but...
Trying to connect the 'new' One on my pc - (Windows 10)and am getting similar download corrupt file message.
This was the corrupt file message when I tried to add the Ultra last week
I can't get an option to setup the One - it takes me back to this with the ultra showing.
Finally, i have also tried to connect the new One on my iphone - uninstalled the App and re-installed and it gets as far as 'searching' but still not connecting
Do I need to have the One dongle plugged into the pc? I didn't think I did for connecting
thanks for any help
Best Answer07-13-2016 14:15
07-13-2016 14:15
You need to plug in the dongle if you are setting it up on the computer.
Download the Windows version here for the PC
https://www.fitbit.com/start?platform=win
Wendy | CA | Moto G6 Android
07-13-2016 14:27
07-13-2016 14:27
Best Answer07-20-2016 08:23
07-20-2016 08:23
I had to delete my app and reinstall it. Do not worry about losing your data. When you sign in, all of your past data will be available.
07-20-2016 08:30
07-20-2016 08:30
thanks all for info - in the end i didn't need the dongle after all as it connected via Bluetooth with my PC, but thank you for help and advice offered by all.
09-01-2016 00:11
09-01-2016 00:11
Hi, I have followed the link provided and when I got there it told me that Fitbit was already installed.
I am trying to connect my replacement ONE tracker but it does not work. The dongle is plugged in. The tracker is fully charged and one inch away from the dongle. I have FItbit installed (not Fitbit Connect) and I am using Mozilla Firefox under Windows 10. I don't know what to do since I am also trying to save my old stats as I resume walking. Any hints? Thanks.
