01-06-2016 18:34
01-06-2016 18:34
Is it possible to sync my One using FitBit Connect w/o using the dongle? When I try to sync with FitBit Connect, it tells me to plug in the dongle - which I don't want to use. I can sync via native bluetooth with the Win10 FitBit app, but I much prefer FitBit Connect as it has a service that runs & syncs even when the app isn't booted which means my data is basically always current.
Best Answer01-07-2016 00:56
01-07-2016 00:56
No, I'm afraid you need to use the dongle if you don't want to use the Windows 10 app.
Is there any reason why you don't want to use the dongle?
Another option is to sync to a compatible phone and avoid fitbit connect and the dongle altogether.
01-07-2016 07:40
01-07-2016 07:40
My PC is laptop which I carry around constantly and I don't like to have something sticking out of a USB port on it.
I do use the phone app (Windows Phone), but that sync'ing from that is problematic as well as it basically has the same problem as the Win10 app in that I need to boot the app for it to sync. As soon as I switch to another app on the phone (or soon thereafter, anyway) I get a notification that 'Background syncing stopped: Open the app to restart syncing'.
So, to summarize:
I guess I'll just need to not rely on having my data sync'd automatically. 😞
