01-31-2025 09:24
01-31-2025 09:24
My old Charge 2 bit the dust (5 or 6 Y.O.), and I bought another Charge 2 to replace it. On the new one, when I press the side button, I get Stopwatch and Relax (not on the old menu), but I don't have a Battery Life icon. Is there any way to remove the Stopwatch and Relax icons, and add the battery life icon? My mobile syncing device is a Samsung Galaxy Tab S7 tablet, but I could not find any help there.
TIA for your help.
01-31-2025 10:20
01-31-2025 10:20
@SCTom46 The Charge 2 has some tracker settings that you control with the Fitbit app. Tap on your device/battery icon, then your Charge 2 tile. Look for tracker settings or a similar phrase. The Battery Life setting is there.
IMO, the Charge 2 was one of Fitbit's best products. I need to warn you that the Charge 2 is a legacy device and was discontinued in 2018. Other users who did what you did are posting that firmware updates are no longer available. Also keep in mind that rechargeable batteries have a lifespan and can degrade even if they are never used. Your battery won't behave like a new, fresh one.
Laurie | Maryland
Best Answer01-31-2025 10:20
01-31-2025 10:20
Laurie | Maryland
Best Answer01-31-2025 10:57
01-31-2025 10:57
Thanks for the help! That was exactly what I was looking for. It was under Menu Items. I overlooked that while perusing through all the settings. Turned the Battery life icon on, and the Stopwatch and Relax icons off.
Happy racing! Think I'll stick to Tennis, LOL 🎾 😎 !!
