11-19-2019
03:51
11:42
11-19-2019
03:51
11:42
This has happened two consecutive nights. Otherwise it’s rarer.
Because the alarm vibration is so subtle, I usually set several at five minute intervals. Last two nights I set six as in 5:00, 5:05, 5:10 etc. I synced three times to make sure they were set. All were good for AM with no repeats.
This morning I awoke on my own during the time I wanted to wake. I had felt no vibration.
When I looked at my alarms, they were set for “tomorrow.” Two consecutive nights.
This happens often enough that I always set a fail safe alarm with Alexa to cover the unreliable Fitbit.
Any suggestions?
11-20-2019 08:25
11-20-2019 08:25
@Coachjim Welcome! It's great to see you around!
Let me help you with your Charge 2 alarms. Start by checking the alarm configuration. If everything is correct then restart your Charge 2. If the issue persist then delete the alarms, save and sync then add them again, save and sync. Also make sure that your tracker isn't in the Do not Disturb mode by long pressing the button.
Let me know how it goes.
