11-02-2018
03:40
15:03
11-02-2018
03:40
15:03
Thought all was going well, had the device 2 1/2 weeks and now the all day sync doesn't work
The heart rate on the app only shows my resting heart rate since this has happened, could this be something to do with the recent ios update on my phone?
I have reset the phone and the charge 3 several times but its still wont let me switch on the all day sync, I can slide the switch across but just get the spinning icon??
11-03-2018 14:41 - edited 11-03-2018 16:39
IPhone 5s
I found someone’s solution.
On phone, go to settings, bluetooth, forget this device.
Then in FitBit app, turn on All-day Sync, let it ask to pair, let it pair.
It worked first try!
11-02-2018 04:41
11-02-2018 04:41
Thanks for stopping by @SunsetRunner! The live heart rate data is related to the All-Day Sync function. You can see live heart rate data by making sure Bluetooth is enabled on your mobile device. In the Fitbit apps for iOS and Windows 10, also make sure all-day sync is turned on.
Let's try the following steps:
Give this a go and let me know if after those steps you're able to turn All-Day Sync on. I'll be around!
11-03-2018 04:25
11-03-2018 04:25
All sorted, seems to be working again after restarting phone and charge 3
11-03-2018 13:05
11-03-2018 13:05
I have exactly the same problem. Followed your remedy, but nothing is different or fixed. What now?
11-03-2018 13:29
11-03-2018 13:29
If @MarreFitbit's haven't helped, may I ask you what phone your having problems with?
IPhone 5s
11-06-2018 08:00
11-06-2018 08:00
Awesome @Jazzle49! I'm glad to hear that you sorted this out after following those steps. Also, thanks for sharing them, I'm sure they will be helpful to anyone who jumps in here facing with the same inconvenience.
Thanks for always supporting the Community @Rich_Laue!
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
12-19-2018 10:47
12-19-2018 10:47
I tried the fix for all day sync. Still won’t all day sync
itwill sync, but no all day or notifications
12-19-2018 10:49
12-19-2018 10:49
That worked for me. iPhone 6s
12-27-2018 17:50
12-27-2018 17:50
This worked! Thank you
01-19-2019 05:04
01-19-2019 05:04
Wow, that worked! Was having same problem with my iPhone 6 - thanks!
01-19-2019 06:06
01-19-2019 06:06
I noticed when I did this that it would work for a few hours or the day. I was continually going into my settings and “forgetting device.”
Feeling frustrated I removed all other things in my Bluetooth settings like my old charge 2 and my car.
It has stayed synced since!
01-27-2019 07:31
01-27-2019 07:31
Thanks! It worked like magic!
03-11-2019 08:53
03-11-2019 08:53
Very easy solution. Thank you! Hopefully we don’t need to do this every morning but it did work.
03-14-2019 15:35
03-14-2019 15:35
Thanks worked first go for me too!
Don’t know why Fitbit haven’t published this solution. Their advice didn’t work!
04-23-2019 08:50
04-23-2019 08:50
Thanks for the advice that’s it sorted
04-23-2019 10:03
04-23-2019 10:03
Thank you so much, @Jazzle49! My Fitbit had been working with All Day Sync for a long time, but suddenly stopped working. I've tried all of the recommended syncing fixes and had a frustrating exchange via Twitter DM with support, but this solution actually fixed the problem after I rebooted phone and app.
05-28-2019 11:40
05-28-2019 11:40
I have done this several times but I'm still having trouble with the All day sync. Sometimes it will go off when I get a text message or a phone call but most of the time it doesn't. I check the app and it says it's been hours since the last sync. I try to sync it and it just spins and says it's been scheduled to sync but then it goes right back to showing me how long ago the last sync was. I've unpaired and restarted and reset several times already. I checked to make sure that the Fitbit app was up to date as well. I've only had this Alta HR for over a year now. Your help would be greatly appreciated.
05-28-2019 15:43
05-28-2019 15:43
When asking about a phone issue, as with all day sync, we really need to know the type of phone.
Thsnkyou
05-30-2019 03:52
05-30-2019 03:52
