06-18-2022
15:34
14:17
06-18-2022
15:34
14:17
Try to get into Fitbit app on iPhone 13, won’t load…. Is there a problem with app? Trying to sync my workouts!!
06-18-2022 15:41 - edited 06-18-2022 15:42
Hello @PumpsWater
Try logging out if the Fitbit app, restart your phone the log back in again as you normally would. If the problem persist make sure your using the latest Fitbit App updated Version
😃Hopefully this provides you with the best answer to get you up and running again. Let me know please
Best Answer06-18-2022 15:51
06-18-2022 15:51
06-18-2022 16:02 - edited 06-18-2022 16:03
@PumpsWater Can you just force shut the app by swiping it upward (iOS) or if on Android tap the three lines in bottom left then tap close all….then restart phone the see if the Fitbit app opens as normal. If the problem persist just uninstall the Fitbit App then reinstall.
😃 Please come back and let me know how it went
Best Answer06-18-2022 17:01
06-18-2022 17:01
