09-19-2019
05:20
12:50
09-19-2019
05:20
12:50
Hello,
My app won’t open. When I click on it, the screen turns white and then it just takes me back to my phone screen.
I’ve shut my phone off and turned off the Bluetooth, but nothing changes. I’ve also updated the app about a month ago. I have an iPhone 6s Plus.
Thank you.
09-19-2019 05:25
09-19-2019 05:25
Strangely, there has recently been an issue with the app crashing at start but this was only introduced with app version 3.6 a little while back so it sounds like your app is older than that. Do you know what version you have? If you are on version 3.6 then try upgrading to version 3.6.1 which fitbit expect to fix the problem introduced with 3.6
See the main thread on this problem at https://community.fitbit.com/t5/iOS-App/iOS-app-crash-3-6/td-p/3760761
If you are running an older version than 3.6 it might be a good time to get up to date. Hopefully the issue will go away.
09-19-2019 13:02
09-19-2019 13:02
Best Answer09-20-2019 07:06
09-20-2019 07:06
I can’t bring up my charge 2 app to open on my IPhone 7. When I go into it from my screen it just flickers back to the screen.
Best Answer09-20-2019 07:25
09-20-2019 07:25
@Koeller are you on the latest version of the fitbit app? This problem was introduced with version 3.6 but fixed with the latest version which is 3.6.1
Best Answer09-20-2019 17:37
09-20-2019 17:37
Best Answer09-20-2019 17:39
09-20-2019 17:39
All is okay now thank you
