09-26-2022
20:19
16:43
AndreaFitbit
09-26-2022
20:19
16:43
AndreaFitbit
I’ve been wearing a Fitbit device for at least 4 years and about 6 months ago upgraded to a charge 4 which I wear day and night, however not long after moving up from the charge 3 to the 4 I started experiencing pains in my wrist, inner elbow and shoulder.
At first is was mild discomfort but it got worse and worse to the point that at times the pain was quite severe.
lit never occurred to me that the cause was the Fitbit until I checked online.
3 days ago I took the device off and within 24 hours the spasms had stopped and so far have not returned.
I’d encourage anyone experiencing these symptoms to ditch your device for good.
08-03-2023 16:38
08-03-2023 16:38
Hello everybody!
Thanks for reaching out regarding this situation with the Charge 4. In this case, please be so kind to contact and report this directly with Fitbit Customer Support. They will help you out! We will be closing this thread, there will be no option for future replies. Please direct to customer support. Have a nice day.
Best Answer09-26-2022 20:48
09-26-2022 20:48
I would think switching arms would be a good test, given that you could still stop right away if you started getting pain in the other arm.
09-29-2022
00:59
16:35
AndreaFitbit
09-29-2022
00:59
16:35
AndreaFitbit
this is interesting ive been experiencing really bad pins and needles in the arm i wear the watch on is this the cause
Moderator edit: format.
09-29-2022 01:27
09-29-2022 01:27
09-29-2022 18:41
09-29-2022 18:41
For the same reasons, I hardly ever wear it at night, and my symptoms disappeared.
Best Answer08-02-2023 11:34
08-02-2023 11:34
I have had a similar experience. I upgraded to a Charge 5 earlier this year and started having pins and needles in my arm within a few months. Mostly at night. It progressively was getting worse. I took my band off on Saturday and I haven’t experienced the numbness. My arm is still a bit sore, mostly at the wrist. I am on the forum to see if there is a way to utilize the watch without having it check in on heart rate, etc. Essentially I would just use as a watch and pedometer. If the issue is from the watch I am hoping there is no long term side effect.
08-02-2023 18:31
08-02-2023 18:31
08-02-2023 19:17
08-02-2023 19:17
08-03-2023 16:38
08-03-2023 16:38
Hello everybody!
