12-26-2021
06:39
16:04
12-26-2021
06:39
16:04
When I move my wrist/arm to check the display, it doesn't wake up. It DOES display when I push the side button. DND/sleep is off. Fitbit is updated.
You press the side button for about 2 seconds and you will see DND, Sleep and Screen Wake. If your Screen Wake doesn't have the Bulb, you just click on it and it will appear. Hope this helps.
In your 'Quick Settings' where I assume is where you checked the other settings, also check 'Screen Wake' light bulb icon. That causes exactly your display and nothing else. I forget which way it toggles on and off but just try switching it.
Best AnswerYou press the side button for about 2 seconds and you will see DND, Sleep and Screen Wake. If your Screen Wake doesn't have the Bulb, you just click on it and it will appear. Hope this helps.
