07-26-2020
18:00
13:17
07-26-2020
18:00
13:17
Charge 3 is not holding a charge which is ironic. Woke up this morning it was completely dead. Charged to 100% and it was dead again by lunch. Charged to 100% again and it will be dead by morning again. Never had this issue before. Worked fine till today.
07-28-2020
11:53
11:40
07-28-2020
11:53
11:40
@Kathyjo422 It's great to have you here!
Let me help you with your Charge 3 battery draining quickly. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
Best AnswerI have tried cleaning it. I also let it completely die and recharge fully twice now. This morning it went to a black screen with 1 line across it. I did a reboot on it. It then came back up to it's normal screen although the time was incorrect. I followed the steps to correct them time but we are still having issues with the battery not lasting a full day.
08-05-2020
07:40
07:17
08-05-2020
07:40
07:17
@Kathyjo422 thank you for the update.
Since the issue persists I have created a case so our Support team can further assist you via email.
Keep me posted.
