12-26-2017
01:46
18:54
12-26-2017
01:46
18:54
How do I get the battery symbol off my fitbit. I left it charging for over a week because I forgot about it. Now will only show battery symbol.
12-26-2017 04:08
08-12-2019 06:48
08-12-2019 06:48
I’ve done this and the battery icon still appears first and shows that is still charging at 75%. What should I do??? I’ve done everything and no success at all.
Best Answer08-12-2019 07:20
08-12-2019 07:20
I don't know of any other things to try so I suggest trying the restart a couple more times and if that doesn't work then contact customer support via contact.fitbit.com
Best Answer06-24-2020 17:49
06-24-2020 17:49
Step1. Plug your fitbit device to charger.
Step2. Press the restart button on your Fitbit device for 4-8 seconds. It will reboot your device.
worked for me.
