01-03-2018
02:20
18:54
01-03-2018
02:20
18:54
My phone suddenly won't find my device.. and naturally it's not syncing anymore either. I have restarted my phone, the Bluetooth is on but still not connecting.
01-03-2018 03:19
01-03-2018 03:19
Having tried restarting your phone without any luck, try restarting your Charge 2:
Best Answer01-03-2018 03:19
01-03-2018 03:19
Best Answer01-03-2018 06:07
01-03-2018 06:07
I have the same problem for ages..
Last sync was 22 June, and i can't get it to sync no matter what i do.
So i tried all kinds of different steps, nothing works. I have removed charge 2 from my account and also from bluetooth. And if i want to pair it with another phone, it just doesn't find anything.
Date and time is off by few months, other than that everything works without the app.
Best Answer01-03-2018 11:51
01-03-2018 11:51
Thank you very much!!! It worked 🙂
Best Answer01-16-2018 22:42
01-16-2018 22:42
If that doesn't work - which it didn't for me with my Charge 2 and HTC One X10, I simply replaced the tracker in the account settings of the Fitbit app. Replacing the tracker re-discovers and re-initialises the connection - and from then on it syncs properly. You don't lose any of the data either.
12-30-2019 08:17
12-30-2019 08:17
This solved it for me, without losing that days steps etc
Best Answer12-30-2019 15:07
12-30-2019 15:07
None of those worked for me. Now what?
Best Answer12-31-2019 01:32
12-31-2019 01:32
@technowaysavvy it might be best to contact customer support via: contact.fitbit.com
Best Answer12-31-2019 07:02
12-31-2019 07:02
thank you, i will contact them
