01-07-2018
14:47
18:54
01-07-2018
14:47
18:54
I play a lot of golf. I got a Charge 2 for Christmas. Does the Charge 2 track golf as an exercise in any way? Can I get data when I play golf other than steps?
01-07-2018 15:16
01-07-2018 15:16
Hi, @GolfProRoy! I would say that the easiest thing would be to run the "workout" from the tracker. That will track your steps, calories, and heart rate for you. You can also rename it to "golf" afterward, if you like.
MakMak | Community Council
Best Answer04-22-2018 01:54
04-22-2018 01:54
Hi,
There's a "Golf" setting you can use (I only discovered it yesterday so I've yet to try it out). Login to Dashboard then click on Settings and then Charge 2.
Click on Exercise Shortcuts and you'll be able to select Golf from there:
Hope that helps,
Paul
05-03-2019 14:16
05-03-2019 14:16
Do you know when they removed Golf as an activity?? I haven't played since last September and It's no longer on my app!
Best Answer07-05-2019 09:35
07-05-2019 09:35
Same question, I was using it but now it's vanished.
How do I get it back?
Best Answer07-05-2019 12:03
07-05-2019 12:03
Logon to dashboard via web browser
Click on your device
Click on Edit next to Exercise ShortcutsShortcuts
Click on Edit button. You should see Golf as an activity:
07-05-2019 14:48
07-05-2019 14:48
Thank you so very much for this information. The activity is now showing up on my fit bit. Not on the app but at least I can keep track when I golf. Your response is greatly appreciated.
