11-09-2017
03:36
18:54
11-09-2017
03:36
18:54
I am facing a peculiar issue with my charge 2.
For 2 weeks it wont charge beyond 85%. When plugged in it is 85% and when I remove still 85% and whenever I check it is still 85%.
Last 2 days it has come down to 80%...
Anyone else facing this issue..
11-09-2017 05:56
11-09-2017 05:56
Thanks for stopping by @Krishnan1974! This is weird my friend... I'd recommend following the steps and tips I've shared in this post to see if your battery gets charged properly.
Let me know how it goes!
Best Answer11-10-2017 03:00
11-10-2017 03:00
Thanks for the reply. have done so but no change..it is static now at 80% for last few days...
Best Answer11-10-2017 04:23
11-10-2017 04:23
Thanks for getting back @Krishnan1974!
Since this sounds a bit more serious, I've created a Support Case on your behalf - you should soon receive an email from Customer Support at the email you used to register with the Community forums. If you have any questions, don't hesitate to let me know.
Best Answer11-10-2017 04:32
11-10-2017 04:32
Thanks and appreciate your efforts in creating a support case on my behalf.
Best Answer12-01-2017 22:46
12-01-2017 22:46
Fitbit team has replaced my charge 2 tracker.
This issue is now resolved.
Thanks again...
Best Answer05-31-2018 10:46
05-31-2018 10:46
I have been having this exact issue for about a week now. My battery won’t charge past 85%. And when I plug it in it reads 85%. But I still get low battery alerts
08-20-2019 06:41
08-20-2019 06:41
I have exactly the same problem. The battery is also only lasting 2 days.
09-03-2019 08:33
09-03-2019 08:33
I am having this issue as well. Starting Sunday, it only charged to 90%. Today it only goes to 85%. I cleaned the contacts and reset the device. Do I need to have it replaced?
09-03-2019 17:20
09-03-2019 17:20
I am only getting one day of use before I need to recharge
I have turned off everything that would use battery and its still a problem.
I need to contact a support person as this is only 8 months old.
Very disappointed.
09-20-2019 10:40
09-20-2019 10:40
I am also having issues with my Fitbit Charge 2 not charging beyond 85% no matter how long I leave it on a charger. Today, it went down to 15%, plugged it in for 2 hours and went to 85%, left it on another 2 hours and never went above the 85%. This has been happening for at least the last couple of months.
What should I do?
09-20-2019 16:19
09-20-2019 16:19
Contact fitbit support and they will help test battery and replace if there is problem and its still under warranty .
Best Answer09-20-2019 21:16
09-20-2019 21:16
Please contact the customer support....When I had this problem, I reached out to them after doing all possible things available in FAQs and response received....Then I reached out to customer support, and they got my tracker replaced...
Best Answer09-20-2019 21:19
09-20-2019 21:19
Please go through the FAQs and the discussion forums and there may be similar cases there and you may find a solution to your issue....Please also reach out to Customer Support and they may be helpful...
