01-06-2020
05:52
19:53
01-06-2020
05:52
19:53
Having similar issue as others here. My Charge 3 is about 15 months old and the screen is blank. It vibrates but no screen. Tried troubleshooting but to no avail.
Did you try a Long Restart?
CHARGE 3 LONG RESTART
Connect the device to the charging cable.
While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration.
The device turns off.
The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
Remove the device from the charging cable. The device shuts down.
Important: Plug the device into the charging cable again.
Best AnswerDid you try a Long Restart?
