07-22-2017
11:36
09:26
07-22-2017
11:36
09:26
Bluetooth not active on charge 2 so cannot connect device to mobile
how can we turn it on
07-22-2017 16:43
07-22-2017 16:43
Hi @Bettyboop50,
Bluetooth is always on with the Charge 2. There's no way to turn it off. What makes you think the problem is on the fitbit tracker? Usually bluetooth issues are related to the phone;s bluetooth. Are you getting a specific error somewhere?
07-23-2017 00:39
07-23-2017 00:39
Hi Bluetooth not showing in Bluetooth devices so cannot connect
however on saying that it is on my iPad but not my phone . I did have it on both for first 3 days
thanks
07-24-2017 07:10 - edited 07-24-2017 07:12
@Bettyboop50 I hope you're doing well! The sync and setup are done from the Fitbit app not from the Bluetooth settings area on your phone or iPad. Make sure that your phone is compatible to sync. In this case you can try restarting the tracker by doing the following:
Plug the charging cable to your computer or UL certified wall adapter.
Align the contacts of the tracker with the charging cable and plug it in making sure it snaps securely.
Your tracker should start charging.
Press the button for 10 to 12 seconds.
You should see your tracker's firmware version and you can now unplug your tracker.
After this restart the bluetooth on your phone. Go to the app and retry syncing them. If by any chance you enable notifications on your iPad then please disable this option there and turn off the bluetooth before you try syncing with your phone.
Let me know how it goes!
Best Answer12-02-2019 17:09
12-02-2019 17:09
My fitbit is connected to my old phone recently i have changed my phone and the my FITBIT ALTA bluetooth is not at all discoverable in the bluetooth devices in my new phone. I have done everything reset, Updates, software is also upto date app reinstalling but its doesn't work. its good on my old phone but its not synced with the new one luckily i have not formatted my old phone so at least the data is in sync but im not gonna use that phone and it gonna be reset now how to resolve.
12-03-2019 15:06
12-03-2019 15:06
Same problem here. Just got a new iPhone 11 Pro Max. My Alta hr data syncs fine, but I can enable notifications. The Alt hr is not showing on my iPhone settings Bluetooth list -- although I have seen it appear twice for very brief periods. The phone is new and the Alta has been working fine with my old phone. Should I assume the problem is with the iPhone Bluetooth?
