08-14-2023
06:28
14:39
AndreaFitbit
08-14-2023
06:28
14:39
AndreaFitbit
Does anyone know where i can get the tracker holder mount for the straps fixed on a charge 4?
Hi @Samfh86 there are no repair parts for these devices, but for your Charge 4, there is a workaround. Amazon sells a "protective cover band for Charge 4" which takes the pebble part and fully encompasses it. You might want to check into it. Most of the people on the forums who had this problem say the bands work for them.
