Broken Strap Connector Repaired! DIY
The plastic connector for the strap on my Charge 4 sheared off spontaneously, literally while sitting at dinner.  My investigation reveals that this problem is common and strongly suggests it is a design flaw.  There are several posts on this topic (search the word "connector").
Assistance from Fitbit was completely inadequate: Discount coupon for a replacement, although there are so many limitations on the coupon that it is worth almost nothing, and it is laughable. There are several posts on Fitbit's trick of offering a Discount Coupon and why the coupon is close to worthless.
So I went about repairing the broken connector on my Charge 4 tracker.  It's not easy, but here's what worked for me (and I think that each and every step and point described below are important):
  1. I had all three of the pieces (since it broke spontaneously in my dress shirt, all of the pieces including the tiny spring were trapped in my sleeve and I saved all of them: tiny spring; push button; broken-off strap connector with two screws embedded in it
  2. I disconnected the remaining wrist strap so that I could study the opposite side to see how it assembles
  3. The tiny screws were still embedded in the piece that snapped off.  It was not necessary for me to remove the screws, and I didn't try.
  4. I cleaned every piece with an alcohol wipe and tweezers to remove all of the crud and get surfaces in good condition for glue
  5. I used tweezers to re-assemble the pieces on the tracker (rather than my fingers)
  6. I practiced re-assembling the broken parts over and over, such that I could do it smoothly, consistently, and accurately without mis-steps or fumbling around.  Every step described is important, and I think this step is very important.
  7. Once I was able to reproducibly reassemble the pieces, I reassembled and then added Crazy Glue to hold the snapped off piece onto the body.
Minor but important details for reassembling and gluing the pieces are as follows:
  1. tracker body is placed screen side down
  2. tiny spring is put into position resting on a nubbin that sticks out from the body
  3. push button is placed over the spring – the push button stays balanced in this position on its own
  4. the piece with screws embedded is then slid in from the side over the "push button"
  5. 1/2 drop (not full drop) of thin Crazy Glue added between broken piece and body.  The Crazy Glue is initially added in just two places -- essentially where each screw/connector broke away from the body.  It is very important to avoid getting Crazy Glue in/around the push button, because the button has to be able to move up/down
  6. I used very strong pressure with my thumbnails on each side of the broken piece to hold the glued piece flush against the body of the tracker until it was secure.  If you instead try to press the sheared-off part onto the body between your index finger and thumb (which is the natural thing to do), this position is unstable. One ends up with the piece wiggling a bit, which is not good for setting the Crazy Glue.  And if one squeezes harder, the assembly buckles and pieces fly everywhere. Instead, I found that thumbnail pressure on the flat portion of the broken piece provided the strongest pressure against the body of the tracker, and simultaneously provided greatest stability
  7. Once this initial bit of gluing is set and dry, I added another 1/2 - 1 drop of Crazy Glue to further secure the broken piece.  I added a small amount of Crazy Glue by allowing it to wick into the space between the edge of the plastic lens and the broken connector.  Again, I used tiny amounts to avoid accidentally getting it on the push button.
  8. Hair dryer used to help set the Crazy Glue. (I set up the hair dryer running on low before I even started gluing the pieces in).
  9. Even though I moved the push button up/down several times when applying glue to try to avoid it from getting glued in place, after the glue dried I found it was difficult to move the button up and down.  The button depressed, but the spring wasn't strong enough to raise the button because of some stickiness from the glue.  I worked the button up and down, but it still wouldn't come up spontaneously.  So to reconnect the strap, I pushed the button down, put the strap in place, and then use a small pin to get under the bottom edge of the button (on each side of the button) to manually raise the button to hold the strap in place.  This shouldn’t be a problem, as the button will not inadvertently or spontaneously depress.  The strap is very well secured.
In addition to practicing the maneuver before actually gluing the piece, I used 1) magnification; 2) extra light to be able to see what I was doing but perhaps that's because I'm an old dude.
I have great confidence in this repair, but only time will tell.  I’m using my tracker now, just like before.
Good luck to all that try this repair.  I feel fortunate that it worked, and that I don't find myself forking over more money to Fitbit.
10 REPLIES 10
Hi there @Gloved, I'm glad to see you around the Community.
Thank for this information and experience shared with the Community, I'm sure many users will benefit from it. I'd like to invite you to visit our Health & Wellness board where you can share your experiences, meet people and create new topics.
Have a good day.
I unfortunately have neither your patience nor your fine motor skills so can't follow in your footsteps, but good on you for accomplishing that! And thank you for posting!!
Hi there @L128. Welcome to Community Forums.
Thank you for reaching out to the Community. I'd recommend you contact Support Team for more information if you are having the same situation.
Thank you so much for taking the time to detail carefully the instructions to fix this. I will give it a go as I am fed up with the watches only lasting just over a year and then having to pay out for a new one! The quality is obviously rubbish and warranty means nothing as they should replace free of charge.
Anyway, off to hopefully not glue my fingers to my fitbit.
Many thanks.
I just had the strap connector break on my 2nd Charge 4. The connector broke on the first one while I was on vacation in Portugal. I rigged up something to hold the Fitbit on my wrist, but unfortunately, it fell out, and I lost it, so I bought a new Charge 4 at an electronics store in Portugal.
I contacted Fitbit support, and they have responded that my Fitbit is out of warranty - however, it is less than a year old.
I saw that a seller on ebay is selling the little connector assembly from otherwise broken Fitbits.
I happen to have a  Fitbit graveyard of old Charge 3s that would not hold a charge. I'm hoping that I can remove the connector from one of them and attach it to my Charge 4.
My first charge 4 broke off and was replaced as was under warranty. Now the second one did the same but just past warranty.  Will try your suggestion. Thank you.
The lugs on my second Charge 4 broke but I was fortunate and both were replaced under guarantee ... one by Joh Lewis and the second one by FitBit.  I mooched around the forum and somewhere on here I found this option for a replacement strap.  I didn't go through with it as was looking for better reviews but it's an option. https://www.amazon.co.uk/Chofit-Compatible-Replacement-Wristband-Protective/dp/B09XMS8427/ref=sr_1_5...
Yeah, I ended up ordering one like that. Other sellers offer multiple colors. I like my new clear one. It matches everything.
It's just disappointing that this forum provides so much evidence of Fitbit's less than quality construction and service. It makes me question their market leader status.
I searched, but could not find the piece that broke off my Charge 4 where the band attaches.  Without that I cannot do your suggested repair.  Maybe I will just glue the band to the watch.  I am sick of fitbits breaking down right after the warrenty expires.  I think I will look for a different brand.
Jean
I ended up resurrecting a Fitbit Charge 3 from my graveyard of Fitbits that died. This particular one was doing crazy things and the battery died within a few hours. But I charged it up and connected it to my Fitbit app, which promptly told me that there was a software update for it. I've been using this Fitbit for over a month now. It doesn't seem to have the same cheap plastic connector that broke on the two Charge 4s that I've had.
When this one dies for good I'd like to find another brand as I don't trust Fitbit's quality.
