08-25-2020
13:25
09:08
08-25-2020
13:25
09:08
Execise shortcuts do not display on C2 tracker. I have tried turning tracker off and on and then syncing; reinstalling app and syncing; wiping out all shortcuts then syncing and then adding desired shortcuts and then syncing again. Shortcuts still do not display. Please help! Thx.
08-25-2020 18:24
08-25-2020 18:24
Is this a new occurrence, or might it just be that you don't know how to get to the Exercise Shortcuts?
Best Answer08-26-2020 06:48
08-26-2020 06:48
I have not tried to change the shortcuts before. The default shortcuts that appear when pressing the button are gone, but the choices i made to replace them are not showing up.
Best Answer08-26-2020 09:56
08-26-2020 09:56
Solved: Exercise was off in menu options.
