10-01-2016
		17:15
		10:26
		10-01-2016
		17:15
		10:26
10-06-2016 06:12 - edited 03-20-2025 08:13
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
It's nice to see you around the Community @Pkpsmall!  I'd recommend doing the following:
Give it a shot and let me know if this worked!
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
 Best Answer10-10-2016 13:55
10-10-2016 13:55
 Best Answer10-11-2016 04:58 - edited 03-20-2025 08:13
Thanks for keeping me posted @Pkpsmall! I'd recommend disable the notifications and re-enable them. If you're interested in calendar notifications, note that most trackers can only display them if they're sent from the default iOS Calendar app. If your third-party calendar app syncs with the default you won't notice a limitation. Only Blaze lets you choose a third-party calendar app directly.
Here are the steps:
Let me know the outcome!
 Best Answer10-20-2016 11:05
10-20-2016 11:05
10-21-2016 04:20 - edited 03-20-2025 08:14
Thanks for the update! I'd recommend doing what I've suggested in my previous post, but before attempting them I'd try disabling your notifications. Once you've done that and also you've followed the steps try enabling your calendar notifications to see if this does the trick.
Keep me posted @Pkpsmall!
 Best Answer02-23-2017 14:11
02-23-2017 14:11
Same issue here. iPhone SE Fitbit charge 2 - all software up to date. I have a recurring event in the calendar app starting every day at 5pm, ending 00:00.
Observation: If I disable Bluetooth during the event and re-enable it, I get a reminder on my Charge 2.
This happens EVERY time.
I assume that the recurring notifications are caused by loosing Bluetooth connection. After connection is reestablished you get notified of all current events.
This could for example happen if the tracker is too far away from the phone.
If you disable iOS calendar notifications then you don't receive the notifications on the tracker.
Result: this behavior is caused by the iOS calendar and is not a Fitbit issue!
Workaround:
Keep tracker and phone nearby and always connected:)
03-19-2018 18:20
03-19-2018 18:20
It is now 2018 and this issue has still not been resolved by Fitbit. I see the topic pop up on many Fitbit products' boards. I think the only solution is to just turn off the calendar notifications. That is a hassle because if it worked the way it should, it's a nifty feature to have. I'll keep an eye out for a solution, but in the interim I will just turn it off. Or, dare I say it, is it time to switch to Apple Watch?
03-24-2018 14:16
03-24-2018 14:16
This issue started happening for me last Saturday...a week later it is driving me nuts. Often I get the notification after the event and repeatedly after that. Just now I was notified 3 times in 5 minutes of an event that had happened 5 hours ago....
03-26-2018 05:22
03-26-2018 05:22
This is happening with my Charge 2 as well, but has only started doing this fairly recently (within the last month), and it only happens, oddly enough, when I have my gym class scheduled on the calendar, and then it continues to go off on my fitbit about 4 to 5 times DURING my class.
03-29-2018 10:02
03-29-2018 10:02
We did all these things and even deleted the event from the calendar and i was STILL getting notifications. Sometimes it’s once or twice an hour sometimes it is three times in a minute.
I have even uninstalled and reinstalled the app!!
What is going on?! 😞
03-29-2018 10:03
03-29-2018 10:03
Did this as well and it didn’t work.
 Best Answer06-12-2020 09:23
06-12-2020 09:23
Still happening in June 2020! Driving me crazy!
07-11-2021 05:48 - edited 07-11-2021 05:49
Still happens on ionic in July 2021. Super super annoying. It’s one thing to know the wrist heart rate isn’t fully accurate ( had a heart attack so I know) , but then when the other features that make it a smart watch don’t work…. With all the cheap alternatives now and Apple competitively priced it’s baffling this isn’t a priority to fix.
 Best Answer04-17-2022 22:58
04-17-2022 22:58
Its April 2022, Still happening on Charge 5. Keep reminding me about the event throughout the day.
