05-27-2019
23:59
15:47
05-27-2019
23:59
15:47
I’ve noticed that my calorie burn for running is 1cal/minute... is this right? All my google searches suggest that it should be more like 10cals/min...
05-28-2019 10:21
05-28-2019 10:21
@RunRaeRun Welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your caloric burn while running. How are you recording your activities? Are you manually logging them or is it being recorded with your tracker? You can enter your own caloric burn if you wish when manually logging your activities. For exercises recorded by your tracker make sure it is detecting not only your movement but also the heart rate. I suggest you clean the back of your device with cotton and rubbing alcohol and restart it. Turn the heart rate off, save and sync then turn it on save and sync again. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes.
Best Answer05-28-2019 13:14
05-28-2019 13:14
