03-11-2018
07:42
18:54
03-11-2018
07:42
18:54
I read on here to click the sleep log I want to change and look for the three dots, but none pop up. I know I’ve edited my sleep before and it seems like the option to do that has disappeared. Any idea what’s going on?
Hello @AnnaPuga, welcome aboard!
Regardless of which method you chose to log your sleep, you can always edit the sleep log to better reflect your time asleep. If you use a Fitbit device with heart-rate tracking (except Charge HR) to track your sleep, you may notice gaps at the start or end times of your sleep stages if you extend your time asleep. Please take a look at the following instructions for iOS devices to edit your sleep:
Let me know how it goes!
Best AnswerI have the same issue as @AnnaPuga. The three dots are no longer there. I've tried to log out of the FitBit app, turn off bluetooth, turn off phone and then restart everything and logging in again. Nothing.
I have the same issue with Charge 2. The 3 dots are missing for last nights sleep. They are there if you look at the previous sleep periods. Whether it's to do with clocks going forward in the UK, I don't know because the wake/end time is an hour ahead, 0930 (GMT) instead of 0830 (BST), despite the time being correct and updated in the app and device and Charge 2.
I'm having the same problem. Had it with the last 2 phones and with the brand new phone. I KNOW how we're supposed to be able to edit our sleep hours. But it WILL NOT allow me to change it. It says the schedule already exists when it isn't showing at all. So, how do you deal with the app refusing to let you change it, or even delete the bad info and add all new info?
