10-26-2019
09:33
12:06
10-26-2019
09:33
12:06
I've been trying for a week to sync my charge 2. The time is about 4 hours off. I restarted the fitbit several times. Sometimes it may or may not come back on. Yesterday it took 2 hrs before it came back on after restarting it. I also removed the fitbit connect app from my PC and added it back. Nothing has helped. I tried to update the fitbit but I'm getting the same error message. An Unknown Error Occurred while syncing.
Moderator edit: title format
10-26-2019
13:15
08:39
AlvaroFitbit
10-26-2019
13:15
08:39
AlvaroFitbit
Contact Customer Support.
08:41
13:27
10-28-2019
08:41
13:27
@sbyrd85 Welcome! It's good that the community is growing! Sorry for the delay in my reply.
Let me help you with your Charge 2 not syncing. Which phone are you using? Is it compatible? You can try the following:
@SunsetRunner thank you for your help here.
Let me know how it goes.
Best AnswerHello AlvaroFitbit, I am using my PC. I updated the app to the current version. Every time I restart my charge2 I have to restart it several times before it comes back on. When it does locate my fitbit, I get an error message.
07:21
13:27
11-04-2019
07:21
13:27
@sbyrd85 thank you for the update and sorry for the delay in mine.
Have you tried using a phone to sync your tracker. It doesn't need to be listed as compatible. Or you could try using a tablet too. Still since the issue persist I have created a ticket so our Support team can further assist you via email.
Keep me posted.
