01-24-2019
19:14
17:54
01-24-2019
19:14
17:54
I set up my Charge 2 last year and it was working great! I recently purchased a new iPad so I downloaded and installed the Fitbit app. I verified my account in the app and went to add the device but it would not sync. I logged into my account at www.fitbit.com and it says that my account is not paired with any devices. Any advice?
01-25-2019 09:31
01-25-2019 09:31
Hello @Lacrosse4Life, let me give you a warm welcome to the Community! In this case, if your Charge 2 seems to be no longer syncing with your account, I will ask you to set it up as a new device. If you have questions about how to do it, please follow these instructions:
Hope that helps!
Best Answer01-27-2019 15:24
01-27-2019 15:24
Best Answer01-27-2019 15:50
01-27-2019 15:50
I have the same problem (I bought a new one that would not connect to my iPhone X), so I called support. They admitted that are aware that the Charge 2 will not connect to the new iOS but do not have a solution (and they have not had one for a long time). We should all send our Chrage 2s back!
Best Answer01-28-2019 08:35
01-28-2019 08:35
Hey guys, I hope you are doin' fine!
@Lacrosse4Life, thanks for trying the instructions I posted to set up your Charge 2. Please take a look at the troubleshooting in this help article: Why can't I set up my Fitbit device? Same to you my friend, @JoeCooooooool, if you were not advised to try those tips when you called Support, please give them a try now.
I'll be around!
Best Answer01-28-2019 17:40
01-28-2019 17:40
I have tried all and more. Support says it is a know problem with connection to the latest iOS 12 "are working on a fix" but I have not seen one in over a month. Any other ideas?
Best Answer01-29-2019 06:24
01-29-2019 06:24
Hey @JoeCooooooool, thanks for your response! By now, I can only ask you to be patient while our team is working towards a solution, and stay tune. 😉
Have a great day!
