06-23-2023
11:45
13:29
RodrigoMFitbit
06-23-2023
11:45
13:29
RodrigoMFitbit
I accidentally washed my Fitbit 3 in the washing machine lol. Anyways, I had my Charge vibrating every 10,000 steps (so 10,000 and then 20,000 and then 30,000) but all my settings disappeared. How do I set it up to vibrate every 10,000 steps? Right now it only vibrates on the first 10,000. Thank you.
06-24-2023 13:35
06-24-2023 13:35
@deezin Welcome to the forums. Thanks for reaching out about the step goal celebration on your Fitbit Charge 3. Glad to hear your Charge 3 is still working even after the washing machine incident.
The celebration goal will be triggered only when you reach a certain amount of steps. It does not happen every time you reach that amount of steps. If it is set up for 10 000 steps, it will only vibrate then. There is no setting to change this. That is how it works. But you can post your comments over the Product Feedback board. This is the best place to make your voice heard. This is where you can submit your ideas and share it with other members. The suggestions with more votes are taken into consideration by our developers for new updates or product development.
Best Answer06-24-2023 13:35
06-24-2023 13:35
