11-24-2018
05:12
03:50
11-24-2018
05:12
03:50
Hey @afesco, it is great to see new faces around!
Ok, on the water consumption part, you can choose a glass (250 ml), a bottle (500 ml) and a big bottle (750 ml) these measurements can't be changed. However, after you tap the water tile, you'll see on the upper right corner a plus sign, so tap on it and you'll be directed to the part where you can enter the amount of water you have consumed and next to it, you can change it to ounces, glass or mililiters. You have the option to manually enter a different amount of water from the one that is there by default. So I hope this helps.
Let me know if you have further questions!
Best AnswerDoes this mean i can change my glass from 8 oz to let's say 10 oz and my water bottle from 24 oz to 21 oz etc?
