Changing from vibrate to SMS notifications
Hey folks,
1st time poster so bear with me if this has already been posted. I tried doing some searches without success. That said, I'm trying to determine if there's a way to change (or additionally configure) my tracker (Charge 2) to send the "Reminder to Move" notifications via Android SMS notifications as opposed to the vibration notifications. The timing isn't an issue as it does vibrate 10 min prior. However, the vibration strength is weak and I don't catch the reminder if I'm concentrating on work. Hearing my phone notification chime would be a preferred method. I've checked the notifications (FitBit App > Account > Privacy & Security > Notifications) which are all enabled.
Thanks in advance!
1 REPLY 1
I my haste to submit this post, I believe I've figured out my own issue. I found I had disabled (Blocked) notifications from the FitBit app on my Android (Samsung S9) device. I re-enabled all notifications in the following setting. Settings > Apps > Fitbit > Notifications. I haven't had a moment to test, however, I believe this may resolve my problem!
