Changing hourly activity time.
My HR tracks 9-6 hourly activilty and thats not good for me. I wake at 5:30 and work till 3:30  and would like to track from 6 AM to 6 PM. How can I change it?
27 REPLIES 27
If you tap the Hourly Activity tile on the app, then the settings button (little cog on the top right), you can customize the hours it counts for 250+ steps. Hope this helps!
Fantastic. Done! Thanks
I can’t change my hourly activities, I have tapped the activity hours on the app, then pressed the right hand cog.  When I change the hours and go back onto the dashboard it has changed but not the hours I have chosen?
I can’t alter mine since the clocks went back last night
Me neither!!! It keeps reverting back to 6am & 3pm for my 9 hours & won’t let me change it to 7am until 4pm which is my usual 10 hours. It’s really frustrating me now!!! 😡
It’s only since the clocks changed is yours the same
Sent from my iPhone
Yes exactly it is really annoying me. It has been suggested that maybe tomorrow it may adjust, not use to changing hours.
Sent from my iPhone
I have emailed fitbit but this shouldn’t happen as they are not cheap is yours a Fitbit charge 2
Sent from my iPhone
Fitbit HR
Sent from my iPhone
Lets see if they reset tomorrow
Sent from my iPhone
If it doesn’t and you get a reply from Fitbit, could you please let me know. It would truly be appreciated.
Sent from my iPhone
Yes I certainly will
Sent from my iPhone
Can anyone help me change the time since the clocks went back . Thanks
Yes, only been an issue today since the clocks went back. I’ve tried all sorts so let’s hope it’s a glitch that sorts itself by tomorrow?! Mine’s the Charge 2.
Mine has re-set it self today
Sent from my iPhone
Mine has reset itself this morning
Sent from my iPhone
I’m having the same issue since the time change. My activity block is usually 9-6...it changed on its own today and everytime I try to change it back, it force-adjusts to its own schedule. 😕 Hope they fix it soon. (BTW, I have an Alta HR).
I’m having the same problem! Since the clocks changed my hours set for tracking 250 plus steps has changed, and no matter what I do I can’t get them to change back. Also my history now shows 13 hours active instead of 14! Frustrating!! Mine is a charge hr.
I don’t understand, as mine did the exact thing but the following day(Monday) it reset itself. I can’t help you sorry
Sent from my iPhone
