04-26-2019
09:23
16:26
04-26-2019
09:23
16:26
My Fitbit Charge 2 says it has Bluetooth issues when trying to connect. "If you see this message For the first time press cancel and try again. If you continue receiving this message, press restart bluetooth to turn bluetooth off and on." I have seen this message so many times I gave up for months. I tried:
If anyone knows the solution or things I could try, I would really appreciate it.
04-28-2019
09:05
10:16
04-28-2019
09:05
10:16
@Stevie123 It's great to see that you've visited the Fitbit Community!
I will assist you with your Charge 2 not syncing and sorry for the delay in my reply. Also thank you for troubleshooting this issue. Which phone are you using? Is it compatible? You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional suggestions here.
Let me know how it goes.
Best Answer04-29-2019 05:02
04-29-2019 05:02
Dear Alvaro,
Thanks for the reply. No worries about the delay it didn't take that long 🙂
I have a OnePlus 6, so yes it is compatible.
After removing all the devices and restarting my phone and fitbit, it still didn't connect.
Both bluetooth and location services are on.
My phone says it's connected to the charge 2, but the app says it's not connected when I try to synchronize it.
I also tried the additional suggestions, but nothing worked 😞
Best Answer04-29-2019 11:11
04-29-2019 11:11
I'm experiencing the same issue. My charge 2 just suddenly stopped connecting to my app last Tuesday. I've done everything listed and I also can't get it to connect.
07-27-2019 15:16
07-27-2019 15:16
I have the same issue and have tried all the solutions listed... The phone (Xiaomi mi A2) could sync until I got an update...
